Remote valve on super dexta
Ed G
02-17-2002 16:57:19
I have a 1963 super dexta and I would like to install a 1 spool remote valve any idea from ford or aftermarket??
Kevin
02-28-2002 17:22:13
 Re: remote valve on super dexta in reply to Ed G, 02-17-2002 16:57:19
A single remote valve might be hard to find. A dual remote valve will be easier. Almost all remote valves off Ford from Hundred, Thousand or earlier Ten series tractors will fit. Our Dexta's we use the remote valve off 4610's, it lays flat rather than sticking up. To make sure you get the right one the base of your selector valve or cover plate will be the same size. (may have more or less holes, that doesn't matter) Once you have the valve go to your Newholland dealer and get a seal kit and your ready to go. You may also need new bolts because some need different lengths than the original.
Hope this helps
Kevin
henning thomssen
02-18-2002 19:28:39
there should be a flow-diverter-valve(i think that is what it's called)on the lift cover,in front of the seat.i believe all dextas came with that from the factory,my '61 has it,i just have one coupler out back,but it's enough for what i do with it(gravity does the rest).it's controlled with the same lever as the 3pointhitch.if you need two hookups,you can always plumb a spoolvalve from that point,you would only need to find a way to return the hydraulicfluid to the reservoir.when i bought my massey50 some years back,i had the dealer install a spoolvalve,and that is how they went about it
