Fordson major gas?
johnny
02-23-2002 18:51:59
just bought a sweet tractor says forson major,is gas and runs great.after i got it loaded seen where something was done to oil pan?--he said the axle pivot broke and the axle cracked the oil pan.number above starter on housing says 123 492 ----- ----- ----QUESTIONS---where could someone find a oil pan for this thing or can it be repaired?he said it was aluminum,can it be replaced without taking off radiater and sheet metal?any ideas on hp?,year?---thanks in advance
ksmith
02-24-2002 18:32:03
 Re: fordson major gas? in reply to johnny, 02-23-2002 18:51:59
I've had oil pans on vehicles repaired. They sand blast them and coat them on the outside with some sort of epoxy. Seems to hold up well. In canada with the road salt. I know of a couple gas majors in scrap yards. Engine parts are near impossible to find. I doubt you could find the parts for a rebuild. Love my major gas but I dread the day it dies!!!!
Stephan
02-24-2002 03:12:14
Hi
Year 1952 around august
Yes oil pan canbe taken of without removing
any sheet metal or radiator
Hp belt= 34
Hp drawbar 28
Repleasement oilpan: depends were you are
around here (holland) no problem
guess it can be welded depends on the crack is
