Fordson year I am not sure 1917 ? Or
Arland Nelson
02-25-2002 19:36:56
My old Fordson is steel front and back it has ..7 spoke wheels /The radiator has solid sides, the drawbar has 5 holes with the middle hole larger. The gas tank is a single compartment With the bead going the full length of the top " should be a early Dearboun tank". The rear housing has No grove on the axel housing The grease couplings are at a angle down. The oil drain is very large on the crank case. It runs but seems like the govenor
Reves to high. The dash board casting has paent # on it but the back has the # 1485 Please advice as to the year ? Iam not sure if I will Totally restore it or sell it.
Ole
02-27-2002 14:10:06
 Re: fordson year I am not sure 1917 ? Or in reply to Arland Nelson, 02-25-2002 19:36:56
The radiator had solid sidepanels after 1917 and the 7 spokes came in early 1919. The serial number on the right side of the engine - between the first and second manifold hole - is the best guide to the year of production. If there is no number there, your engine is a later exchange engine.
Terry
02-26-2002 16:02:50
Your tractor is more than likely a 20-22 model year. They serial # is on the right side of the engine block towards the front under the exhaust manifold. If you can make it out, post it. This can sometimes be deceiving because the engine could have been exchanged over the years. Sounds like you have a nice tractor.
