Major 3 pt weight capacity
kfsmith
03-02-2002 13:30:54
I have a 1952 new major. I would like to use a 3pt hitch sprayer on it. I've found a 200 gallon with a 37 ft boom. Could the tractor handle this without weights on the front or am I going to be in trouble with a full 200 gal of spray. If not ... what would be the capacity of this 3 pt.
Thanks
Stephan
03-03-2002 06:15:14
 Re: Major 3 pt weight capacity in reply to kfsmith, 03-02-2002 13:30:54
Hi The capacity is about 1600 kilograms. And a major with cast iron front rims will
lift its nose if you use this capacity to the max (at least mine does)
Hope this helped a bit
