FMD gearbox
American farmer
03-16-2002 01:36:03
Why do that FMD´s make such gearbox noises?
Or is it just a worn out gearbox?
I was told that this is pretty normal.
L. Harvey
03-17-2002 21:37:06
 Re: FMD gearbox in reply to American farmerboy, 03-16-2002 01:36:03
The noise is normal. The gearbox in a fordson major diesel and power major is the exact same gear box as in a kerosine major. At least as far as I know. The kerosine major needed 90w oil in the gearbox because the gears are straight cut and because the clearances are very broaud. The 90w oil stoped the noise. But because the diesel major and power major added hydroulics the oil needed to be thinner. So in essence you are using 20w or 30w oil in a gearbox designed for 90w oil. That is what creates the noise. But DONT go putting 90w oil in your gearbox or diff. It is perfectly fine running 20w or 30w, It is just a bit noisier in a few gears. And 90w oil would kinda wreck your hydroulics. I will note that it was fordson trying to be cheap by not putting a seperate tank for the hydroulic oil. All they had to do to stop it was have a seperate tank for the hydroulic oil and they could have put 90w oil in the gearbox and diff. BTW. The noise is nicknamed the fordson crunch.
Regards
L. Harvey
American farmerboy
03-17-2002 23:14:41
 Re: Re: FMD gearbox in reply to L. Harvey, 03-17-2002 21:37:06
My manual recommends 90w for both, the primary gearbox and the diff.
Is it really bad for the hydraulics?
L. Harvey
03-18-2002 17:47:00
 Re: Re: Re: FMD gearbox in reply to American farmerboy, 03-17-2002 23:14:41
Every one I know says that 90w oil will wreck the hydroulic pump because it is way too thick for it. Also it is not good for any external attachments either. And my manual says to use 30w oil in the diff and gearbox. Mine is an 1967 I&T Fordson manual for a my 1960 power major. Anyway I use cheap 20w oil because it is about 70% cheaper than the cheapest 30w oil I have found. But no side affects yet. And I have owned this tractor from new. I am inclined to think it is a typo in your manual. Of course I may be wrong but I dont think I am. I just had a look at a past post. It said 30w or 20w. If you want to have a look at this post go to this address >Link
Regards
L. Harvey
American farmerboy
03-18-2002 22:46:29
 Re: Re: Re: Re: FMD gearbox in reply to L. Harvey, 03-18-2002 17:47:00
What if i there´s 90w in and there´s still the fordson crunch?
L. Harvey
03-19-2002 00:24:23
 Re: Re: Re: Re: Re: FMD gearbox in reply to American farmerboy, 03-18-2002 22:46:29
That is a good question. Honestly I wouldnt be able to tell you. Would I be correct if I guessed it happaned only when it is pulling heavy loads. But honestly I wouldnt have a clue.
Regards
L.Harvey
