Hey Burrhead need some help!!
cappy
03-19-2002 12:11:29
I'm having trouble getting the rear main seal on my Dexta to quit leaking. Got any Ideas. Also how do you get the seal all the way down into the retainer before putting it on, and is there a gasket that goes on between the retainers and the block?
Needs help Cappy
Burrhead
03-20-2002 18:27:47
 Re: Hey Burrhead need some help!! in reply to cappy, 03-19-2002 12:11:29
Cappy yes there is a gasket for between the block and the seal retainer but I always just put a thin layer of silicone and no gasket.
The way I do the seal is like this.
I put the new rope into a can of oil and leave several hours.
Then with the retainer in the vice I start to roll the new rope down into the groove til it bottoms out. If I cannot get the rope completely in place with my fingers I use a tooth brush plastic handle as to not gouge the new rope.
When you have the rope in place you want at max of .020 and minimum of .010 rope protrusion out of each end of the retainer.
Now put a small film of high temp silicone in between the halves, now put the 2 halves in place with the 2 joint bolts finger tight to hold the halves together.
Put the seal retainer six bolts that hold it to the engine/rear main in place but don't tighten yet.
Now tighten the 2 bolts that connect the retainer halves down to about 25 ft pounds.
Next tighten the 6 mounting bolts down to about 25 ft pounds.
The only failures I have ever seen on the rear main was caused by too much or too little rope protrusion and I have seen the retainer caps leak around the new seal from stress cracks.
cappy
03-20-2002 21:35:08
 Re: Re: Hey Burrhead need some help!! in reply to Burrhead, 03-20-2002 18:27:47
Thanks burrhead you sound like a real pro. I will try to do all this on Fri. The gasket is what I've been leaving out. I have a new gasket set and it's got 2 in it. Should I use both or did they give me 1 to many?
Thanks again.
Cappy
Burrhead
03-21-2002 14:28:35
 Re: Re: Re: Hey Burrhead need some help!! in reply to cappy, 03-20-2002 21:35:08
They must have given you one gasket too many.
Mike
03-22-2002 08:00:19
 Re: Re: Re: Re: Hey Burrhead need some help!! in reply to Burrhead, 03-21-2002 14:28:35
Thanks Burrhead, I'm getting ready to start rebuilding my Dexta and the info will come in handy.
Mike
cappy
03-21-2002 22:30:07
So you wouldn't use this gasket, just some high temp silicone? I can use the gasket or silicone, which one would you use. Thanks again.
Cappy
Burrhead
03-22-2002 21:46:14
 Re: Re: Re: Re: Re: Hey Burrhead need some help!! in reply to cappy, 03-21-2002 22:30:07
I always use the high temp silicone and hang the new gasket on a nail in the wall. Just don't over do it with the silicone as a thin film will seal just fine.
cappy
03-24-2002 14:46:59
 Re: Re: Re: Re: Re: Re: Hey Burrhead need some help!! in reply to Burrhead, 03-22-2002 21:46:14
Thanks again Burrhead for all the information. I will get this done this week. By the way Burrhead this person who asked you the question about the differential and used the name Cappy was not me there must be 2 of us. HA HA. Well thanks again
Cappy
