Fordson Model N (timing)
Jon S
03-25-2002 18:06:06
Hello, I'm new to the tractor tinkering hobby..I bought an old Fordson model N tractor...It has steel wheels all around and its all orange in color....I had the magneto gone thru..but can't seem to get her timed right....Any ideas would be appreciated...
Andrew from Australia
03-26-2002 22:23:12
 Re: Fordson Model N (timing) in reply to Jon S, 03-25-2002 18:06:06
When I time my Fordsons I do the following: (Works for me but I'm no "expert mechanic"!)
Set the engine to top dead centre on cylinder number one.(The first cylinder back from the fan) (I take the plugs out of 2,3 & 4 after cleaning around them to stop dirt falling into the engine. I turn the engine up to the top of compression. The bolt through the pulley is either vertical or horizontal.I can't remember which, sitting here at the computer!) Sit the magneto on the engine with the cap off. Look to see which terminal in the cap the rotor is pointing to. Now sometimes the cap is labelled with one. If so, turn the maggie backwards (anticlockwise) until the rotor lines up and this should correspond to the engine with the loose "drive coupling" in place. With existing leads it's obviously the terminal going to cyl 1. It doesn't really matter where you start if you're starting from scratch and have to fit leads as well.
Fit the maggie with one bolt. Turn the engine over again and check that when the maggie trips on compression (only on number one) that the rotor is again pointing to cyl 1. If so continue to fit bolts and leads. Remember that the rotor turns opposite to the direction of the armature. The order of firing from memory is 1243. Make sure each terminal and lead lines up to the right plug as the rotor goes around. It can get a bit confusing when the wires are in the tube!
Hook up the advance and retard control. Remember to start it retarded! This is with the lever at the top position. Fully turned clock wise (from the seat) should turn the ignition off. Turning it anticlockwise advances the spark for when it is running.
I hope this helps and that I haven't confused you further. I also have an orange Fordson N. Mine is a 1938 model.
Regards
Andrew
Jon S.
03-28-2002 18:06:34
 Re: Re: Fordson Model N (timing) in reply to Andrew from Australia, 03-26-2002 22:23:12
Thanks for the information...I'm going to head out to the shed and see if I can get her running
Andrew
04-01-2002 17:18:22
 Re: Re: Re: Fordson Model N (timing) in reply to Jon S., 03-28-2002 18:06:34
By the way, I swapped maggies on my 1951 E27N Fordson major on Sunday. Changed it to a hotter one to make it easier to start! When on top dead centre the bolt through the pulley should be horizontal. I couldn't remember when I replied to you!
Let me know how you go with your tractor.
Regards
Andrew
