E1ADKN rear axle oil leak
Bob D UK
04-26-2002 15:48:13
I have oil coming out of the nearside axle tube and running down the inside of the rear wheel. It has been suggested that there should be no oil at this level and that the most likely explanation is that the seal between the gearbox and the rear axle is leaking, which has caused the oils in both to mix, causing the level to increase to a point where it is running out of a location that was not expected to be oil-tight. Proposed solution is to drain off some oil until the level is below the axle tube and that the tractor will still be OK to run with the reduced level. Does anyone have any experience of the problem and the proposed solution, please?
james stewart
09-21-2003 03:44:15
 Re: E1ADKN rear axle oil leak in reply to Bob D UK, 04-26-2002 15:48:13
we had the same broblem with our fordson. The diff and gearbox have the same oil. The seals have worn out
Stephan
04-27-2002 08:49:06
Yep you are right see my reply at Oscars page
Regards Stephan
