Fordson major gearbox question
farmer joe
04-28-2002 10:53:14
When i drive my fmd with low engine rpm, there comes a noise from the tranny. The noise also appears when the tractor runs downhill with the engine brake at low rpm.
Is that normal?
All gears are easy to shift, there are no metal splinters in the oil, no other signs of a gearbox failure.
I´ve heard about the Fordson crunch, what does it sound like?
Mike
04-28-2002 20:35:10
 Re: Fordson major gearbox question in reply to farmer joe, 04-28-2002 10:53:14
Joe.
Have you checked your transmission fluid lately, doesn't hurt to take a look at the rear end at the same time as noise can sometimes travel on a shaft connecting two components, good luck.
Mike
