Fordson major diesel
jeff
05-04-2002 10:28:39
There is a loud rattling sound coming from the front of the engine by the injector pump. I've heard these engines are noisey but what kind of noise is it that can be expected.
Paddy
05-05-2002 07:53:30
 Re: fordson major diesel in reply to jeff, 05-04-2002 10:28:39
Sounds like a worn injector pump coupling, just replace that, thats the fibre disc joining the drive shaft from the engine to the injector pump
Tom
05-08-2002 01:42:24
 Re: Re: fordson major diesel in reply to Paddy, 05-05-2002 07:53:30
When i replace the pump coupling, do i have to remove the injector pump?
Or is it possible to replace it without removing anything?
Thanx Tom
brian britt
05-17-2002 03:45:14
 Re: Re: Re: fordson major diesel in reply to Tom, 05-08-2002 01:42:24
to remove the coupling you have to undo the four
injector lines on the pump undo the four bolts
underneath the pump undo bolt at the front of the pump shaft holding the clamp next undo bolt on the
drive shaft clamp to slide coupling off pump will
slide back to allow this make sure all timing marks are aligned before removing .
