Fordson starter
kelly
05-06-2002 10:57:24
i have a 1957 fordson, on the sheet metal covering the engine it says" fordson major 5000"
i am in need of a starter for theis tractor, or information and someone who can rebuild the one i have.
thanks in advance
kelly
TMAC
05-08-2002 03:54:46
 Re: fordson starter in reply to kelly, 05-06-2002 10:57:24
I did like Dave. Bought a new starter for a Ford 3000. Cost just $125 and I didn't have to trade in the original. I have a picture of it on my FMD and I can email it to you. I haven't yet learned how to post pics with my replys.
Peter, U.K.
05-07-2002 03:18:21
Kelly, Any good auto-electrician should be able to clean and re-build your starter.
Dave
05-06-2002 18:29:05
The starter went bad on my super major a few years ago, and I replaced it with a starter from a Ford 4000. Had to make a few modifications, like relocating the tool box and setting up a separate push button starter switch, but it wasn't that bad of a job, and the starter works great, a lot more pizzaz than the old one. If I remember right, parts for my original starter were either unavailable or very expensive.
Carl
05-09-2002 08:28:58
 Re: Re: fordson starter in reply to Dave, 05-06-2002 18:29:05
I have a 55 FMD and the starter is bad, starter shop said no parts are available. Can get a replacement for $150 but will have to change the bendix as # of teeth is not correct. Question for Dave or TMAX, did you have to change bendix or will the 3000 & 4000 work?
Dave
05-12-2002 08:45:56
 Re: Re: Re: fordson starter in reply to Carl, 05-09-2002 08:28:58
Carl - I had to make a few modifications to my Super Major to accomodate the 4000 starter - like relocating the toolbox to the other side of the tractor and setting up a starter button on the lower instrument panel. And the oil diptick has to be curved slightly to get past the body of the new starter. But I didn't make any change to the starter itself, it bolted right in. What I don't know is if your Major is different from my Super Major in some way that would require a change in the bendix.
