Tractor ID,need help
Don
10-11-1999 11:07:47
I'm looking at a tractor(to buy)no ID on it.
except for a medalion on front of radiator,oval
shaped,silver color with what looks like a gear
or cogged wheel along with a hand holding what looks like wheat stalks.The tractor is yellow
color,4cyl diesel ,Simms injector pump,3 pt hitch,
single gear shift lever,compression release lever
on front of valve cover,batt.located behind valve
cover just in front of fuel tank.Any clues????
appreciate any help
jack
10-14-1999 19:55:08
 Re: Tractor ID,need help in reply to Don, 10-11-1999 11:07:47
It sounds like my power major check the # on the right front (the right when you are sitting in the tractor seat) of the the head. Then go to the site>Link
and>Link check the number there. good luck!
Brian
10-11-1999 13:58:46
Don,
Sounds like you have found an industrial Fordson Major around 1955 onwards. Serial No. should either be on the block just above the injection pump on a flat area or could be on the houseing above the starter. Brian
