Parts source for a 57 Major
George
05-17-2002 06:09:25
After just buying a what turned out to be a 57 Major. After getting it home, changed the oil and added water, a lot of water. Then water started showing up in the oil. Have the head off at the moment, there were no really obvious proplems with the head gasket, however, there were two head bolts that were not as tight as the rest, and they were also used to mount the p/s pump bracket. Cleaning the mating surfaces and then going to pressure test the block for leaks around the sleaves. In anycase I have not found a parts source as of yet, and was wondering who the US folkes used to get the needed parts, like headgaskets?
Paddy
05-19-2002 08:39:04
 Re: Parts source for a 57 Major in reply to George, 05-17-2002 06:09:25
Get in touch with a man called David Thrower, he has customers from other countries but is based in England. He does a headset for a major for £38.
His number is (UK Code) 01359240251
Hes really good,he does every part you can imagine, he strips old majors for parts you see. He also buys new ones (liek headsets, exhausts, manifolds, tyres etc)
He has the best prices for tires ever
Good luck - Paddy
