Smoking
Gary
05-28-2002 17:54:15
I have 2 questions.I just bought a fordson dexta and as you set on the seat on the right side of the engine is what looks like some type of breather pipe.It comes down the side of the engine which is a diesal by the way.The question is should it smoke out of the pipe?Second question is it all right to use ether if the glow plut don"t work? Thanks Gary
Peter, U.K.
05-29-2002 00:46:03
 Re: smoking in reply to Gary , 05-28-2002 17:54:15
Gary 1) This sounds like the engine breather - does it come from the rocker cover and run down the right side of the engine? It shouldn't smoke - if it does this could be a sign of oil burning due to worn rings. 2) Never, never use ether to start an engine, this will result in serious piston damage - try to fix the glow plug.
Hope this helps, Peter.
