Rebuild
Gary
06-02-2002 04:41:55
One more question.The dexta I have after you run it 15 to 20 minutes it starts putting white smoke out the blow by pipe.I would not call it bad or terrible lot it justs starts putting out some smoke.The question is it going to make it any worse to keep running it that way or should I try to overhaul it right away?thanks for all the information.
Paddy
06-05-2002 04:00:50
 Re: rebuild in reply to Gary, 06-02-2002 04:41:55
Sounds like a blown head gasket or fractured head, somewhere water is getting into the bores, and that white smoke is actually steam
I would rebuild it ASAP because otherwise the water rusts all your valves out, i know this because it happened to mine, and it didnt take long because the water had antifreeze in it which is very corrosive.
Rebuild as soon as you can
Good luck
