SEAL PROBLEM ?
BRIAN
06-02-2002 21:05:33
WERE IS THE OUTSIDE SEAL ON THE REAR END SHAFT IS IT IN THE HOUSING WIYH THE BEARING AND DO YOU HAVE TO HAVE THE BEARING PRESSED OUT TO GET TO THE SEAL AND HOW DOES THE BEARING KEEP GREASE ON IT. BOY I AM JUST FULL OF QUESTION'S BUT I NEED HELP. OH! IT'S ON A FORDSON DEXTA 1958 OR 1962.
BRIAN
capbuster
06-03-2002 20:52:46
 Re: SEAL PROBLEM ? in reply to BRIAN, 06-02-2002 21:05:33
Are you talking about the pto shaft or the axle? I think you are talking about the pto shaft. You have to drain the oil out of the rear end then take the bolts out from around the shaft and pull out shaft and bearing, then you can put in a new seal. If it's the axle, there's 2 seals, one in the housing which is easy to get to, then there's another one on the axle itself. It could be a doozie. If you have a manual it will show you a picture of what you have to do. If you don't let me know and I'll scan you a picture from mine. Hope this helps.
Capbuster
BRIAN WOODS
06-03-2002 22:55:27
 Re: Re: SEAL PROBLEM ? in reply to capbuster, 06-03-2002 20:52:46
IT'S ON THE BACK AXLE IN FRONT OF THE BEARING.
I WILL SEND YOU AN E-MAIL TO GIVE YOU THE DETAILS.
THANK YOU
BRIAN
capbuster
06-04-2002 20:43:34
 Re: Re: Re: SEAL PROBLEM ? in reply to BRIAN WOODS, 06-03-2002 22:55:27
Brian,
I sent you a scan of the axle, let me know if it helps. Also if you can see the scan. I just got me a new scanner and you are the first I've sent to. Take care.
Capbuster
