Need starter
J. T. Clements
10-16-1999 20:12:13
Need parts to rebuild starter or starter for dexta super. location or other info would be greatly appreciated. perkins 3 cylinder diesel.
JJ
10-17-1999 07:03:24
 Re: need starter in reply to J. T. Clements, 10-16-1999 20:12:13
If you aren't able to find them at a local starter shop you may have to get them from a Ford or Ferguson tractor dealer. The parts are readily available for the starter and generator.
If you have a NAPA nearby they should have the brushes and bushings in stock for both, they might have them listed as a Lucas rebuild kit.
The starter and generator are both made by Lucas.
The starter from newer model 3 cylinder Perkins engines either Massey Ferguson or Ford will fit the bolt pattern to mount the starter, but the selonoid will be different, so that it cranks with button or key instead of the lever.
Oscar
10-18-1999 05:42:55
 Re: Re: need starter in reply to JJ, 10-17-1999 07:03:24
If all else fails you can get a starter sent from Holland. There's plenty of 'em around.
