Super dexta cooling probs.
James
06-19-2002 12:16:35
I have a 63 Super dexta . when i removed the top hose block on the head there was no thermostat, was i looking in the right place.
Also when i opened the tap an the blok nothing happened so i unscrewed the tap from the block and it is still not letting any water out. I suspect there must be a blockage someware. any help please. Thanks.
Henning Thomssen
06-19-2002 18:26:42
 Re: Super dexta cooling probs. in reply to James, 06-19-2002 12:16:35
Looks like you were looking in the right place for the thermostat.Your coolingsystem appears to br full of rust,that settled on the bottom in the block,happens when the antifreze gets too old,like 10 years or so,try poking around in the drainhole with a piece of wire to get it to drain.Then I'd hook up a gardenhose to that and try to flush the block.Just leave the thermostathousing off for that.Probably you rad will have some of that dirt in it as well.Best to take it off the tractor and try flushing it,too.
