Super dexta hydraulics dropping.
James B
07-07-2002 06:18:54
On my 1963 super dexta when i hook up an implament on the 3pt linkage and lift it up it drops slowley and won't correct it self even with the control leaver right up it will drop all the way down. I was wondering what position the position/draft leaver should be in when lifting implaments.
Any help thanks
Burrhead
07-07-2002 11:17:42
 Re: Super dexta hydraulics dropping. in reply to James B, 07-07-2002 06:18:54
if we're talking about the same control --the lever has a "F" for fast and "S" for slow beneath the lever in the housing.
The control handle moves the draft lever from slow to fast the higher you raise the implement.
If the draft lever is in the slow position and the lift handle is in raised position it will not have enough pressure flow to keep the plow heighth adjusted.
