Verifying fordson model
Paul
07-10-2002 21:03:26
Can anyone tell me how to ascertain the year of a tractor i have just taken possession of? I am in australia & the unit is ( i think ) a fordson dexta. How can i make sure it is a dexta & not a super dexta & how can i verify the year?
Would appreciate any help anyone can give me. Cheers ;-)
JJ
07-11-2002 15:42:43
 Re: verifying fordson model in reply to Paul, 07-10-2002 21:03:26
If it has any original paint left you can tell the difference: Dexta=blue/orange and Super Dexta=blue/gray.
Burrhead
07-11-2002 15:10:30
you can do a visual check. If the injector pump is a Simms mechanical gov it's a Super Dexta. If it has a vacuum gov on the injector pump it's a straight Dexta.
Bob D UK
07-11-2002 12:30:37
Look on the left of this page under 'Research & Info' - 'Serial Numbers'
Paul
07-14-2002 01:40:52
 Re: Re: verifying fordson model in reply to Bob D UK, 07-11-2002 12:30:37
????serial numbers!!!! non of the serial numbers on this fordson tally up with those numbers on all the sites I have been to. serial pre fix is 3B462, serial # is 222 and the model # is 9114 ( all these #'s are on a plate affixed to the "firewall".)Stamped # on the clutch flange (left hand side)is 2649,..and finally the # stamped on the head beside the exhaust outlet is 1501281.The injector pump is a simms with a diaphragm governor on it ( no oil level to worry about? ) so i'm assuming it is a straight dexta. ??? but what year???? Can anyone shed any light on this for Me?
Burrhead
07-14-2002 21:13:31
 Re: Re: Re: verifying fordson model in reply to Paul, 07-14-2002 01:40:52
yep with a vacuum diaphram gov it's a strait Dexta, not a Super. The 2649 on the flange is the serial # and makes it a 1958.
The diaphram injector pumps did'nt have oil lube, they lube from the diesel fuel that travels thru there.
