Super 1961
Josh
07-11-2002 10:01:57
what oil goes in trans? and plug to left of wheel
thats stering wheel
PKgregory
08-07-2002 08:54:20
 Re: super 1961 in reply to Josh, 07-11-2002 10:01:57
Hyd/trans oil in both gearbox and tranny. New Holland #134D or any of the new 10/30 Hyd/Trans oils. About 20 litres (5 gal pail) in the gearbox and about 45 litres in the tranny. My gearbox (large filler plug just ahead of the tranny dipstick) was dry when I bought my '61 but now it shifts super smooth.
PKgregory
08-07-2002 08:57:17
 Re: Re: super 1961 in reply to PKgregory, 08-07-2002 08:54:20
Sorry, I should add ... the previous recommendations for hyd/trans oil is for a 61 Super Major.
Mark Myers
07-15-2002 10:08:55
This is another good source to ask questions.
Link
On the majors discussion board, Brian Dye is the Major man there. He is quite knowledgable....
Good luck!
Mark
Paul
07-14-2002 10:16:07
Does anyone know an easy way to install a new fanbelt and powersteering belt without having to take the shaft for the hydraulics off first!!!???
Ours is also a Fordson Major about the same age- not sure of the exact year. It has a drop in fuel filter, not a screw on, so I guess that makes it older than younger:) The best thing about it is how easy it starts! Then in purrs like a kitten.
josh
07-12-2002 09:14:54
burrhead its a super major
Burrhead
07-13-2002 11:53:52
 Re: Re: super 1961 in reply to josh, 07-12-2002 09:14:54
I don't have a book on Majors but I called my local Ford dealer his book says 80-120W on tranny and diff both. I did'nt think to ask the capacity.
josh
07-13-2002 14:02:50
 Re: Re: Re: super 1961 in reply to Burrhead, 07-13-2002 11:53:52
oops oil dealer said too put trans hyd in plug in front of step is this wright?
Burrhead
07-13-2002 18:16:03
 Re: Re: Re: Re: super 1961 in reply to josh, 07-13-2002 14:02:50
Josh I'm getting in over my head maybe a Major man will show up soon, but it will work to fill thru the check plug. You'll just have to pump it in or use a hose and funnel. That's the check plug you found. There should be a filler plug in the top of the housing .
josh
07-14-2002 15:16:32
 Re: Re: Re: Re: Re: super 1961 in reply to Burrhead, 07-13-2002 18:16:03
burrhead. il be major man soon too.
email me for pik of this sad old
one lost paint what should i paint it?
she scared me s***tless today.
on way home on hill she soundled like was dieing.
open up throttle ran ok. opened up hood.
hot oil out everything then died thought sezied her up. turned out needed lil ??
so was i right hyd oil on plug rightby step.
trans has to have straight 140 gear oil/ same in diff. major here is geting new rings/ cluch in fall. paint too.
Burrhead
07-11-2002 15:07:45
If it's a Super Dexta it's 90W in trans and diff both.
