Super Dexta compression test?
Darren Roberts
07-13-2002 19:15:24
I have 270 psi per cyl.Add oilto cyl.jumps to over 300psi.Tractor will not start without ether.At idle or not laboring the engine emits blue smoke that has rich unburned diesel smell.Tried it at advanced timing.Problem still exists.Injectors have been rebuilt.Do I need an over haul? Thanks Darren Roberts
Burrhead
07-14-2002 12:12:37
 Re: Super Dexta compression test? in reply to Darren Roberts, 07-13-2002 19:15:24
compression should be 400 minimum.
It could be that the valves need adjusted too. They all set at .010 with engine at operating temp.
If it's had much ether thru it then it could be broken rings, cracked piston's or cracked sleeves.
D Roberts
07-20-2002 17:23:01
 Re: Re: Super Dexta compression test? in reply to Burrhead, 07-14-2002 12:12:37
I appreciate your advice.You have helped me to face the facts.Be talking to you again. Thank you much.The compression spec was a big help. Darren Roberts
