Model F Fordson
Nick
07-29-2002 09:30:02
Has anyone repaired any gas tanks for Model F Fordsons? I have one that has pin holes in the bottom in several places. Some are as large as
1/8" in diameter. Can the tank be repaired by using the gas tank sealer materials I have heard about?
ADAM
08-04-2002 20:02:09
 Re: Model F Fordson in reply to Nick, 07-29-2002 09:30:02
I have always had good luck soldering the holes shut then applying several coats of tank sealer,( waiting a couple of weeks between coats)
beware which brand of tank sealer you buy. i used a white colored liquid that did not last for a year, have used the "RED COAT" brand for a long time, good stuff.
Rich Fear
07-31-2002 21:12:11
I have sealed my tank using sealer materials however mine were only very small not 1/8th" I dont know how effective the sealer will be on those size holes. A friend of mine cut the ends off his tank and welded in two new tanks to cure has problem. Once welded up and painted no difference could be seen. With holes of that size I would suggest that you search for a new tank. I dont know how common they are in the states here they can be picked up fairly easily if you do abit of hunting
Good luck !
Rich.
