Installing timing gears on '63 FSM
Mark Myers
08-07-2002 05:34:22
I finally got my head from the shop, and my gasket set arrived via post yesterday, so I am preparing to resurrect my FSM. My question is, since I cannot remember if my cam was turned during the removal of the timing gears, what are the procedures for installing them. My assumption is to set #1 piston at TDC, then begin installing the gears so that the tick marks line up. Is this correct??
Thanks,
Mark Myers
Arlington, Texas, USA
Steven B
08-08-2002 04:05:46
 Re: Installing timing gears on '63 FSM in reply to Mark Myers, 08-07-2002 05:34:22
Mark
You are quite correct.
1 Install the auxilary shaft gear.
2 Install the small cam gear with marks lined up.
3 Install large cam gear with marks lined to crank gear with crank on TDC.
Steven
Mark Myers
08-08-2002 05:49:23
 Re: Re: Installing timing gears on '63 FSM in reply to Steven B, 08-08-2002 04:05:46
Thanks!! I appreciate it!!
Mark
Steven B
08-07-2002 19:54:11
Mark
I will email you tonight after I get home with the procedure.
Steven B
