1920 FORDSON SPECIFICATIONSCOOLING CAPACITY = 11 GALLONS (SOFT WATER/ANTI-FREEZE) ENGINE OIL CAPACITY = 2.5 GALLONS (15W-40 DIESEL RATED) REAR / TRANS. OIL CAPACITY = 3 GALLONS (85W-145 GEAR LUBE) KEROSENE FUEL TANK CAPACITY = 21 GALLONS STARTING GAS TANK CAPACITY = .5 GALLONS AIR WASHER = 1.5 GALLONS (WATER) CUP GREASERS = USE WHEEL BEARING GREASE STEERING JOINTS = USE HEAVY MOTOR OIL FRONT AXLE TRUNNION = USE HEAVY MOTOR OIL FAN BEARINGS = USE HEAVY GEAR LUBE SPARK COMMUTATOR = USE LIGHT MOTOR OIL SPARK COIL CONTACTS = .031" GAP SPARK PLUGS = .031" GAP SPARK TIMING = LEVER C.W. (UP) ADVANCES SPARK, LEVER C.C.W (DOWN) RETARDS SPARK, ADVANCED TOO FAR CAUSES DULL KNOCKING, RETARDED TOO FAR CAUSES OVER-HEATING, FULLY RETARD FOR STARTING, ADVANCE AFTER STARTING TO MAXIMUM SPEED, ENGINE RPM = RUN AT 1000 RPM MAX WHEN WORKING, IDLE DOWN WHEN NOT WORKING, SPEEDS @ 1000 RPM 1ST GEAR = 1.5 MPH, 2ND GEAR = 2.75 MPH, 3RD GEAR = 6.75 MPH, REVERSE = 2.5 MPH 1ST GEAR = 12 RPM @ REAR WHEELS, 2ND GEAR = 22 RPM @ REAR WHEELS, 3RD GEAR = 54 RPM @ REAR WHEELS, REVERSE = 21 RPM @ REAR WHEELS
