I don't know about the tach Capp. I use a hand held electric LED that all you do is point at the crankshaft pully and pull the trigger. When I went back through what we had said I noticed I had made a mistake on the discription. If the old diaphram is the original or a Ford replacement diaphram in it, the diaphram should be leather- it's not rubber unless somebody has replaced it before with and after market rubber diaphram. You are right it fits into a groove in the housing like a seal. I use Vaseline on the diaphram to preserve and slick it a little bit, and a plastic tooth brush handle to seat it. The only things I can think of to do when reinstalling is to rub the new diaphram down good with Vaseline Petro Salve, and you might take some super fine emery cloth and shine up the housing a little where the diaphram goes in it. Sometimes the slot can be aggravating to hit, just be careful and make sure the new diaphram is seated good in the groove. If you need a pic of any part of the tractor just holler and I'll either figger out how to use my new scanner, or I can fax a copy to you.
