Fordson Power Major Starter Motor
Shane
10-21-2002 00:21:10
I Have a FPM that when it is hot will not engage and start the engine. The starter motor turns but does not engage. Its fine when it is cold. Any idea's would be very much appreciated.
Also, could anyone please tell me the pattern and the tourque requirements for the head on a Fordson Power Major Diesel.
One last question, does the Simms injector pump require any oil to be filled in it externally.
Thanks in advance.
Steven B
10-21-2002 00:56:27
 Re: Fordson Power Major Starter Motor in reply to Shane, 10-21-2002 00:21:10
Shane
I cured mine by installing one extra clutch plate in the starter over run clutch pack. A good auto elec that does tractors and trucks should do that for you. I see your in Aust, same as me.
Good luck
Steven
