Starter for a 58 Dexta.
Bernie Guettler
11-01-2002 17:50:38
I would like to know where I could get a starter for a 58 Ford Dexta Deisel. I checked with NAPA and they have one listed for a 59 and 60 Dexta. Is the one on a 58 different? Thanks for any information.
Bernie
capbuster
11-03-2002 20:55:24
 Re: Starter for a 58 Dexta. in reply to Bernie Guettler, 11-01-2002 17:50:38
Paul's got some sound advice for you. If that don't work, it might be your cheapest bet to go to a rebuilding place. They can do it for half the money. Only look around and get the best one. See ya.
Capbuster
Paul
11-02-2002 18:03:52
Cant really help you with the info your after, however i'm wondering if your starter is really in need of replacing. I thought mine was gone just recently & actually found I just needed to scape out the division lines on the commutator & replaced a brush spring & it was fine. If you have a Dexta manual ( I&T )it shows how to adjust the switch. The other thing I did was to replace or clean to a sparkling finish each and every electrical connection associated with the starter, and that includes the solinoid. Actually I pulled the solinoid off & cleaned the body where it contacts the frame & installed an earth wire from there to the wiring harness main earth just below it. Made all the difference in the world. I thought I was up for several hundred dollars for a replacement one & it turned out to be just elbow grease & some electrical connections. Just a thought for you anyway...
cheers.....Paul....8^)
