Fordson 1956 FMD Liner Problem
Mark Saxon
11-06-2002 00:47:48
I finally bit the bullet and pulled the liners on
my old Fordson. I took advice on this list about making a puller.
There was some corrosion but the real problem could be a real problem.
The liners had been done at some point in the past but done badly. They must have been driven out form below with a steel bar or drift.
In the process one cylinder has a small section of
flange above the grove that takes the liners seal is chiped off.
Can I fill this with something? Can I just put it all back together with new seal and hope for the best?
Mark
Steven B
11-06-2002 00:57:05
 Re: Fordson 1956 FMD Liner Problem in reply to Mark Saxon, 11-06-2002 00:47:48
Mark
Are you in Australia (looked at your email address). I am sure you can pick up a block cheap at a wreckers. I would not waste new parts and a gasket set on a suspect block. It could end in tears.
Mark Saxon
11-06-2002 01:17:01
 Re: Re: Fordson 1956 FMD Liner Problem in reply to Steven B, 11-06-2002 00:57:05
Steven
Yes WA I'm pretty sure it was your advice on the oil in the water problem and specs for a home made puller that I followed. You were quite right they were in pretty tight.
What do you think a block would be worth. The
only local wreckers is close to the ocean just a few miles.
I'm a bit concerned any block there could
be a bit of a lottery.
Any ideas on a reliable wreckers in VIC or NSW
Steve B
11-06-2002 14:23:51
 Re: Re: Re: Fordson 1956 FMD Liner Problem in reply to Mark Saxon, 11-06-2002 01:17:01
Mark
Try the following
Ershau Tractor Wreckers in Melbourne, 03 9794 9344
Leo Wgnell in country Vic, 03 5795 2691.
Also "Wests Tractor Wreckers" in Albury NSW. I dont have the number but try the yellow or white pages on line. If you cant find it I will have it at home.
Steven
Steven B
11-06-2002 22:42:28
 Re: Re: Re: Re: Fordson 1956 FMD Liner Problem in reply to Steve B, 11-06-2002 14:23:51
Number for West's is 02 60215471
Leo wignell
11-08-2002 02:51:55
 Re: Re: Re: Re: Re: Fordson 1956 FMD Liner Problem in reply to Steven B, 11-06-2002 22:42:28
We may be able to assist you with a block, give us a ring 03 57 952691 Parts are still available for this engine. We have just supplied a complete kit for a guy in Queensland for a 6 cyl. version of same engine. Regards Leo Wignell
