Fordson Major Diesel
Howard Bishop
11-06-2002 03:21:54
Can someone please help me? I have a FM 4 cylinder diesel with the no. FIADKN7252 on the sump. It also has ENFU or ENFO in several places.
I have no idea what model or year it is and I want to get a manual so that I can repair the brakes and do any maintenance that it requires.
I have no problems as far as it starting and running.
Thanks
Regards Howard
Bob D UK
11-08-2002 10:31:05
 Re: Fordson Major Diesel in reply to Howard Bishop, 11-06-2002 03:21:54
The serial number of your tractor (it's a Fordson New Major E1A) may be on a plate on the firewall between the engine and the battery compartment - on the engine side. Or look for it on a flat below the No. 1 injector (later models), or in any event it should be stamped vertically on the casting at the back of the starter motor. If you at the left hand side of this page, you will see a link to Serial Numbers which will help you tie it down.
manny
11-07-2002 01:41:37
Howard,
Look around the motor for the serial no.
Fordson Majors went from 1952 to 64.
Manuals are still available for them.
hope this helps, Manny
