Right angle drive magneto
chris
11-26-2002 19:42:30
I was digging around in a pile of mags and found a magneto that is mounted to a mid housing and then to a drive housing that is driven at a right angle and wanted to know what this mag is from, one place said it belonged to Ford Motor Co., it's a fairbanks morse type fm, 628697 and J4B73 is stamped in the mag, all that I see stamped in either housings is the number 2, thanks for any help chris
Bernie
12-01-2002 18:16:58
 Re: right angle drive magneto in reply to chris, 11-26-2002 19:42:30
I have Fordson F that had a mag like that. It bolted across the bottom front of the engine behind the radiator. The gears were stripped when I bought it (not running). I couldn't find gears so I sawed the back end of the casting off, mounted it on a bracket on the side of the radiator, and ran it chaindrive off the camshaft.
