Gasket for Fordson F carb against manifold
norm
12-06-2002 06:26:58
I am restoring a 1925 Fordson F. Gasoline is leaking between the kerosene warming plate and the exhaust manifold (winding path between the carb and the piston). When I took it apart, it didn't seem to have a gasket but I assume there must have been one or perhaps it didn't need one with kerosene. It doesn't seem to me like metal against metal can hold warmed up gas. Any suggestions regarding what can be used (i.e. must tolerate high heat from exhaust manifold and gasoline)?
Thanks!
raymond
12-10-2002 16:30:42
 Re: gasket for Fordson F carb against manifold in reply to norm, 12-06-2002 06:26:58
Mine doesnt have a gasket either. It should seal with just metal to metal it could be warped (can be fixed by filing it flat with a flat file or be milled on a milling machine
Ron
12-12-2002 09:08:13
 Re: Re: gasket for Fordson F carb against manifold in reply to raymond, 12-10-2002 16:30:42
Norm,
Do you have the Holley 295 set-up on yours?
