Mounting of chain stabilisers to Dexta
Damon
12-10-2002 16:51:44
Dear all, when I purchased my dexta it did not have any stabiliser bars or chains fitted. It reduce lateral movement of implements I have decided to purchanse and fit a set of universal chain stabilisers as sold by bareco (picture on www.bareco.com.au).
What I would like to know is where do I mount the chains to on the lower lift arms? If I mount them to where the yokes attach for the lift assembly I think the chains will be too short. Do I have to drill new holes towards the rear of the lower lift arms?
Your help will be greatly appreciated.
Damon
capbuster
12-10-2002 19:48:48
 Re: Mounting of chain stabilisers to Dexta in reply to Damon, 12-10-2002 16:51:44
That's what I had to do it works really good to.Use a 1/8 drill bit first then go the the size of the mount you are going to use. I think they are 3/4, but don't hold me to that. Burrhead will know. See ya.
Capbuster
Damon
12-10-2002 21:52:57
 Re: Re: Mounting of chain stabilisers to Dexta in reply to capbuster, 12-10-2002 19:48:48
Capbuster, where did you drill the new holes or is the position not extremely vital?
Regards,
Damon
Burrhead
12-11-2002 16:46:29
 Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Damon, 12-10-2002 21:52:57
here's how I connected mine
Damon
12-11-2002 17:05:57
 Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Burrhead, 12-11-2002 16:46:29
Burrhead,
are the chains you have pictured the internal check chains (run from brackets near the PTO shaft to arms) or external stabiliser chains. The ones I paln on fitting are shown on the link below
Link
Regards,
Damon
Burrhead
12-11-2002 19:50:25
 Re: Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Damon, 12-11-2002 17:05:57
I put the internal pto brackets Damon.
When I tried the external it was too much hassle for me to get the sway out and still have enough lift.
With the external I could'nt get the rear wheel off the ground when I had my bushhog floating.
The internal is agravating because I have to slip the clevis to widen the arms when hooking different implements but the plus side is the higher lift and less adjustments.
I used 5/16" chains and grade 5 bolts with 1/4" angle iron for my arm anchor hitch.
Damon
12-11-2002 20:08:57
 Re: Re: Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Burrhead, 12-11-2002 19:50:25
Burrhead,
I have the internal check chains but they are not the type that are easily adjusted. I will try the external type as they are pretty well standard on newer tractors and I like the ability to easily adjust between implements. I will see how I go.
Thanks,
Damon
capbuster
12-11-2002 20:45:41
 Re: Re: Re: Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Damon, 12-11-2002 20:08:57
I got both on my tractor and they work real good. There's a hitch pin on the underside of the bracket for the fender and come down the arm to within 6 or so inches to the end and drill you a good hole. Be sure you drill it so you have a perfect hole, and unperfect hole will make it a weak spot on the arm. I made my stabilisers and when I need to spread em out a little I just unhook one, put my plow or disk or whatever on and then unhook it back up. I have had great success with this. I could send you a picture Damon if you'd like.
Capbuster
Damon
12-11-2002 20:50:13
 Re: Re: Re: Re: Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to capbuster, 12-11-2002 20:45:41
Capbuster,
for some reason my tractor doesn't have the brackets under the mudguards for the stabiliser chains so I have had to by them. Hopefully I will get all the bits this weekend and then have a look at putting it all together. I have a chisel plough that likes to swing into my right rear tyre so I have to fit the chains.
Thanks,
Damon
capbuster
12-12-2002 21:11:12
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Mounting of chain stabilisers to Dexta in reply to Damon, 12-11-2002 20:50:13
Mine has a short piece of 3/8 angle iron mounted to the same bolts that holds your fenders on, with a hitch pin bolted through a drilled hole. Hope this helps.
Capbuster
