Fordson super major
Logger
12-15-2002 19:19:07
Just bought a super major, the three point arms won't lift.. any ideas... the hydrolic pump is working... but still no lift. I have experiance with ford tractors, but this is my first one fromk the other side of the pond. Any help would be greatly appreciated.
Frank DeBenedetti
02-26-2003 20:10:22
 Re: fordson super major in reply to Logger, 12-15-2002 19:19:07
I am currently looking for a Fordsen Super Major Tracotr power steering pump & resevoir. If you have one or of know of someone who does please send me an e-mail @ the above listed e-mail address. I can also be reached in the U.S. at 1-209-887-3317
Pat
01-16-2003 12:46:45
Make sure the pump inlet screen isn’t plugged up with ice, sludge, etc.
edwin
12-17-2002 12:43:08
not all super majors have a dual clutch but the pto has to be turning it possibly is a sticky valve. try levering the top link yoke with a bar to activate the draft control plunger it might shift something.otherwise is the knob in front of the seat in (in for lift arms out for external hyd if fitted)
Rick Davis
01-14-2003 10:53:58
 Re: Re: fordson super major in reply to edwin, 12-17-2002 12:43:08
When I first purchased my Super Major I had the same problem. Turned out that my auxilary spool has detents in forward and reverse. When the lever is in any position other than centered the lift arms will not operate. And of course the lever on the aux is in such a position that if you move your right leg you almost always engage it.
61fsm
12-16-2002 18:49:05
I had the same problem with my Super Major. I found that the unloading valve was sticking. After replacing the o-ring on the valve the hydraulics work perfectly. If you have a service manual, it will explain the procedure. Good luck.
someone
12-16-2002 03:51:58
The power take off has to be engaged for the 3 point lift to work. It is the lever on the left side of the transmission housing near the steering arm. Clutch pedal has to be depressed all the way down when you try to move the lever. I believe Super has a two stage clutch.
Logger
01-18-2003 05:58:42
 Re: Re: fordson super major in reply to someone, 12-16-2002 03:51:58
Thanks for all the input guys, The problems was that the lift cylinder, located under the top cover, was completely sheared off. It was just hanging by one semi sheared off bolt. A new one has been installed, and it is working. However the 3 point quadrant lever needs some adjustment. Thats a job that can wait untill the weather warms up a bit. Thanks for all the input. Logger
