Fan belt for 1928 Fordson tractor
Lamar Burd
12-18-2002 19:34:16
Can anyone tell me where I can obtain a fan belt for a 1928 Fordson tractor? The original was a flat leather belt. I'm told that the engine in this tractor is the same as the Model "T" engine but the fan belt may not be the same because of a difference in the placement of the radiator (and fan) relative to the engine.
Bob Scott
01-12-2003 19:43:00
 Re: Fan belt for 1928 Fordson tractor in reply to Lamar Burd, 12-18-2002 19:34:16
Try The Fordson House Escanada Mich.
Lamar Burd
01-18-2003 05:51:02
 Re: Re: Fan belt for 1928 Fordson tractor in reply to Bob Scott, 01-12-2003 19:43:00
Thanks for the tip about The Fordson House. Do you happen to have an address or phone number? LB
Bob Scott
01-18-2003 20:25:25
 Re: Re: Re: Fan belt for 1928 Fordson tractor in reply to Lamar Burd, 01-18-2003 05:51:02
The address I have is 717 Stephenson Ave., Escanada Mi.49829 906-786-5120; fax906-7866989. Got this from Dec 2002 Farm Collector magizine.The part # I have on file is S591.Hope this is a help to you.
ADAM
12-19-2002 12:34:33
The Fordson engine and the model T engine share some same design ideas, four cyl., flywheel-magneto ignition, coils, however the fordson engine is much larger. check out the link for a replacement belt, good luck,
ADAM
ADAM
12-19-2002 12:38:14
 Re: Re: Fan belt for 1928 Fordson tractor in reply to ADAM, 12-19-2002 12:34:33
link did not work last time, here it is
