Sediment Bowl
FordsonFan
12-22-2002 08:05:51
The sediment bowl on my 25 Model F is leaking. Instead of the conventional plug at the bottom of the bowl, someone (years ago) substituted a large cut-off bolt. Not being a purist, I'm OK with this if it doesn't leak. It hasn't leaked until now. Have tried teflon tape and a variety of gasket combinations with no luck. Am considering using RTV or some silicone type bead around the bolt head to seal it in. Will RTV hold against fuel?
Will@ont.ca
12-29-2002 18:46:08
 Re: Sediment Bowl in reply to FordsonFan, 12-22-2002 08:05:51
At any hardware store or a TSC store you can buy the right drain tap for it "1/4" inch and with a little tefflon tape it should be a seal for you. WILL
FordsonFan
12-29-2002 19:14:06
 Re: Re: Sediment Bowl in reply to Will@ont.ca, 12-29-2002 18:46:08
Will,
Thanks. Think I finally got it taken care of. Used a bunch of teflon tape and some Permatex thread seal and it's been holding for 6 days now.
Don H
12-22-2002 10:54:45
Not sure about the rtv but possibly an oring around the bolt might work. I am not familure with what you are working on so this just a wild guess.
Don
FordsonFan
12-22-2002 13:50:36
 Re: Re: Sediment Bowl in reply to Don H, 12-22-2002 10:54:45
Don,
Already tried the O-Ring along with the gaskets. No dice.
capbuster
12-23-2002 21:45:35
 Re: Re: Re: Sediment Bowl in reply to FordsonFan, 12-22-2002 13:50:36
I used the red silicone on my dexta combustion chamber covers. I also put it on the copper washer on the injectors, I let it dry over night and it worked like a charm.
Capbuster
