Dexta
porky
12-23-2002 16:32:19
First? where is the serial numbers on the dextas.Second ?when was the wheel colors changed from orange to white or vise versa Thanks and happy holidays
kevin
12-24-2002 20:19:06
 Re: dexta in reply to porky, 12-23-2002 16:32:19
64 and up had white wheels. 63 I'm not sure, my 62 has orange wheels.I beleive from 65 it was called Ford 2000
capbuster
12-23-2002 21:41:54
Hey Porky, go to Oscars site and you can find out all you want to know about your tractor. The orange was used in the United Kingdom on their tractors, and the Ford Grey is used here in the states. White was never used on the dexta that I know of. Someone may have put that on it themselves. See you. If you need any help just holler.
Capbuster
porky
12-24-2002 05:10:44
 Re: Re: dexta in reply to capbuster, 12-23-2002 21:41:54
Thanks capbuster I will do that
Damon
12-23-2002 16:56:20
Porky,
the serial number on the dexta is located on the flange that is located between the engine and clutch housing. The directions that I received from Capbuster (Another very helpful user of this discussion forum) was:
Just look to where your fuel filter housing is, then look to the right a few inches, to where your bell housing connects to the motor. Running vertical down the flange will be a number. It may be covered over with grease or paint, but this is where it is. Get this number and go to Oscars site and match it up with serial numbers on his site. You can find out what model it is then and more.
Regards,
Damon
porky
12-23-2002 17:31:14
 Re: Re: dexta in reply to Damon, 12-23-2002 16:56:20
Thanks damon what or where is oscars site Thanks again
Damon
12-23-2002 17:59:00
 Re: Re: Re: dexta in reply to porky, 12-23-2002 17:31:14
Porky,
Oscar is a another person commonly on this forum. He has his own website packed with fordosn information including serial numbers and a copy of the dexta operators manual. the address for his site is:
www.fordson.freeweb.nl
Regards,
Damon
porky
12-23-2002 19:13:35
 Re: Re: Re: Re: dexta in reply to Damon, 12-23-2002 17:59:00
Thanks again damon found it it is a 59
