Square baling with a dexta
Damon
01-08-2003 20:20:25
Dear all,
I am wondering if a dexta is able to handle a square baler. I live in Australia so not all the equipment listed on this site is found here. The problem is my dexta only has a single stage clutch.
The area that I will be using to make hay is only small, about 5 acres, it is a more of an enjoyment and to provide feed to a few horses. The land is relatively flat.
Is there any older square balers that I should look out for that operate well?
Thanks in advance,
Damon
mike
01-08-2003 22:59:12
 Re: Square baling with a dexta in reply to Damon, 01-08-2003 20:20:25
While baling with a tractor with a 2 stage cluch is easier. I have to sometimes bale with my 800 Ford that is also a single stage clutch, If I get a heavy charge of hay or have to stop for some other reason, I have to back up 10-15 feet so that the 275 New Holland baler I use can get up to speed. My neighbor uses a Dextra with a 2 stage clutch and a MF square baler that does and excelent job of making even weight tight bales... Hope this helps
Damon
01-08-2003 23:03:16
 Re: Re: Square baling with a dexta in reply to mike, 01-08-2003 22:59:12
Mike, thanks for your comments. What model is your neighbour's Massey baler?
