Fordson-F and Fordson-N Compatibility for Hamilton Transmission
Gene
02-01-2003 01:28:15
I recently purchased a Fordson-F with a Hamilton transmission. No serial number can be read on the engine block, but other indications would suggest that the tractor is approximately a 1923. The engine is bad, and I would like to move the Hamilton transmission onto a more powerful Fordson-N engine, probably about a 1938. What will be the compatibility issues at the engine-transmission junction? This is essentially the same as asking if it will work to bolt the front half of a Fordson-N onto the back half of a Fordson-F, joining the two at the engine-transmission joint. I realize that the air cleaners are there and are different between the Fordson-F and Fordson-N. But what about the bell housing bolt pattern, engine-clutch details, and similar mechanical issues? Will it work?
