Rod bolt torque
Dane
02-17-2003 21:33:24
Does anyone know what the rod bolt torque should be on a 68 County Super Six?
Steven B
02-18-2003 03:28:57
 Re: rod bolt torque in reply to Dane, 02-17-2003 21:33:24
If its a 330 CID engine (100mm bore) rod bolts are 55 to 60 ft lb.
If its a 360 CID (105mm bore) rod bolts are 85 to 90 ft lb.
This is for engines with dry sleeves taken fron the Ford D Series truck workshop manual, same engines as fitted to county tractors.
