Fordson Major Diesel
Rear 3PH hydraulic problem.
Rob
03-06-2003 13:52:22
Hello,
I have a 1953ish Fordson Major Diesel. The rear 3PH assembly is all there but the control is REALLY stiff and the hydraulics are NON-operational. It almost appears if perhaps the pump is broken or ?
It has been this way since I purchased it (4 months ago), but until it warms up a bit from the -25 weather we're getting, it'll have to wait till pring to come apart. I was just wondering if anyone had any advice or tips for things to look for / try out, with this problem?
Also, located here in Quesnel, BC, Canada, parts are almost impossible to locate. Anyone know of a good source of parts for these tractors?
Thanks in advance.
You may reply to me at rhors@westfrasertimber.ca
Rob Horstman
H BAR Ranch
Quesnel, BC
cliff
03-14-2003 20:36:59
 Re: Fordson Major Diesel - Rear 3PH hydraulic problem. in reply to Rob, 03-06-2003 13:52:22
You probably have moisture in the hydraulic oil! It is not visible but has emulsified with the oil. Best thing to do, change hydraulic oil, in spring. For now I suggest you pour a can of gas line anti-freeze (methel hydrate) in the hydraulic dipstick hole, within 45 min. the hydraulics will work. I have been doing this for the last 5 years at the sign of cold weather with no effects on the system. An old farmer, deisel mechanic gave me the advice years ago. Let me know if it works!
