Fordson dexta surges
david
03-11-2003 19:34:46
Need help with my 58 dexta,it surges at low and mid rpm's.I just bought it from a older man who rebuilt the motor and had the injector pump rebuilt.He also put a new diaphram in the governor,but he did cut and crimp the fuel primer line.would that make a difference in preformance.
Todd Allen
03-12-2003 19:38:47
 Re: fordson dexta surges in reply to david, 03-11-2003 19:34:46
Check the hose at the air cleaner as I have heard these can cause this problem!
Paul
03-15-2003 19:38:30
 Re: Re: fordson dexta surges in reply to Todd Allen, 03-12-2003 19:38:47
Service the air filter. Check there isnt a leak in the vac line from the diaphram end of the injector pump to the intake manifold, or that there is a blockage of some sort. Either of these could be causing the problem. The diaphram may have been installed incorrectly. The mesh on the air cleaner takes some cleaning, but it can be a source of the "hunting". Good luck.
