Shim sham
paul s
03-12-2003 03:52:09
This old 55 Fordson Major has only some shims between axle housing and body and between brake housing and body How many ?WHAT THICKNESS?and any other tips would sure be a help I'm at a loss as where to start.
Majorman
03-12-2003 09:05:52
 Re: shim sham in reply to paul s, 03-12-2003 03:52:09
The shims are to adjust the engagement of the crownwheel in the pinion. You will need the lift removed and a proper movement gauge to set this up. This may be a specialist job
