Engine is rebuilt and runs great for ten min's
dieing engine
03-12-2003 10:19:53
I have a 52 and it runs great, everything is working.
The problem is when it gets warm it dies or if I
go from forward to reverse (direction) quick.
I have drained the fuel and opened the carburator looking for fuel restriction.
Also put a new condesor in and cleaned the plugs.
Nothing helps.
Any good ideas ?
dieing engine
03-13-2003 10:17:18
 Re: engine is rebuilt and runs great for ten min's in reply to dieing engine, 03-12-2003 10:19:53
Just to clarify my tractor is a 52 8N Fordson,
I have now found the problem in case anyone should run into a similar issue.
above the fuel cut-off valve there is actualy a fuel filter. Said filter was blocked just enough that fuel would actualy flow and even looked like
a good flow, hahaha it's gas engine and needs very much fuel.
The flow was not enough.
Hope this may be of help to someone.
