Waking Major
Dennis
03-18-2003 07:54:15
What would be the best way to get a diesel Major going that has been at rest for many years?
Also, is there a place with pictures that would explain all the controls?
Pat
03-18-2003 15:14:55
 Re: Waking Major in reply to Dennis, 03-18-2003 07:54:15
Dennis, you can find a operators manual for the Fordsons at,>Link
Assuming>Link the engine is still loose, and a diesel, pull the rocker cover off, get a rubber mallet and give each rocker arm a bump on the valve side to see if all the valves are loose, “make sure the push rods stay in place”. having stuck valves hit by the pistons can make for a bad day! if every thing looks OK close it back up.
Drain out any old fuel, clean fuel pump bowl and screen. Probably not a bad idea to replace the fuel filter also. dump in some new fuel, open the bleeder on the injector pump, operate the fuel pump by hand untill the air is bled from the system. Tighten the bleeder on the injector pump. Check all the fluid levels, coolant, engine oil, gearbox oil, and differential oil. With the compression release in the up “released” position, and the stop lever/cable in the stop position, hand crank or bump the motor over a few cylinders at a time to make sure nothing is binding, grinding, or self destructing. Now spin the engine over with the starter untill the oil pressure gauge is showing sufficient pressure for a little bit. OK. This is the fun part, close the compression release, make sure the stop lever is in the run position, and start it up. It will run rough for a while untill all the air is out of the injector system. After awhile if every thing looks good take it outside wipe some of the bird poop and spider webs off, have your girly take a picture of the Fordson and you with a smile on your face and post it here for us to see!
Dennis
03-18-2003 15:42:26
 Re: Re: Waking Major in reply to Pat, 03-18-2003 15:14:55
Pat,
Thanks for that response, I never would have thought about stuck valves.(The engine is free)
This tractor has been sitting at a friends for several years, and I am considering buying if once it starts, but did not want to do damage doing so.
Is the Major diesel much like the Supers for controls, the tractor is about an hour away, I want to make sure I have the right info.
Seems to be in average to good shape, not a Super Major with the Ford colors (Like tractor Dan's)which I would rather have, but will be considerably cheaper.
Pat
03-18-2003 16:03:15
 Re: Re: Re: Waking Major in reply to Dennis, 03-18-2003 15:42:26
The Majors are basically the same as the Supers, the hyd. Controls are a little different, and the throttle is down on the right side opposite the starter lever.
One other thing to check, crack open the oil drain plugs to drain off any water that may have settled in the bottom.
Good luck, and we do want a picture
