Fordson Gas Timing Problems ...
Stu deJong
03-18-2003 18:44:18
Ok so i got this fordson dexta with the same motor as a 2085 massey in it from what i can tell.... it ate the timing chain because someone who previously overhauled it, put the crank gear on backwards....so the gears were not in any way lined up fer timing anymore...the gears that were on it had a big toothache so i get some new gears and a chain ... Neither the gears that were on it or the new ones appear to have any reference marks for timing. I have spent hours timing up on #1 tdc thru flywheel hole and getting the distributor which is still in the correct relation to the cam to look at #1 both at tdc or 5degrees btdc .... it runs but not right just wont idle down....i have gone ahead a tooth back a tooth up to 3 either way just doesnt run right backfires thru exhaust and intake ... im at my wits end just cant make it rite any help would be greatly appreciated ...
Don@ld
03-22-2003 09:48:04
 Re: Fordson Gas Timing Problems ... in reply to Stu deJong, 03-18-2003 18:44:18
Hi,the timing on thise engine is a litlle bit
complicate to explene and my englih is not very god but if your email adres is ok i can try to
seed you the book info i got,and hope it will
help...
