59 Dexta injector pump
Ben C
04-03-2003 06:55:24
Tractor will start on starting fluid, but won't continue running, appears injector pump is not doing its job, pumps some fuel but not up to good pressure, pump was rebuilt several years ago and tractor sat for several years without use, are there any adjustments to the simms vacume governor pump or anybody have any other suggestions, motor is in good shape with good oil pressure, thanks.
Don H
04-03-2003 14:09:32
 Re: 59 Dexta injector pump in reply to Ben C, 04-03-2003 06:55:24
I would check the cheaper stuff first. Fuel filter, tank and primer pump. Low presure pump. You have probably already done that though.
Good luck Don
