Steven,(and anyone else who can help) I tried to pump oil through the filter hole as you suggested, it seemed to have oil in it already. I've got oil coming through the rocker arms, but it just oozes, should it be squirting out? Also, there is a hole on each of the rocker arm assembly supports, it looks like oil should be coming out of them. No oil is coming out of them, should it? Now I've got oil to the gage, but it still doesn't give a reading, does the gage have a membrane that could have dried out? Regarding re-assembly of the oil pump, should I have used a gasket on the cover, does this keep the pumped oil under pressure?? My I&T doesn't mention it and there didn't seem to be any evidence of one.` The tractor's history is a mystery. This is my first engine work, and I just want to be sure its right. Thank you Thank you
