FMD fuel lift pump repair kit?
Jacob Helton
05-13-2003 19:25:33
I have a Fordson Major and the lift pump started to leak between the pump and engine block (bad gasket, by the way). I installed a new gasket for the time being, however the leaking fuel will go into the oil. What could be bad inside the pump? Some sort of diaphram? Is there a repair kit or should I buy a new one for $100? I have found one source for the new pump, any other sources you folks suggest? I need this tractor to mow hay this week! Thanks for any help.
ray
05-16-2003 07:23:35
 Re: FMD fuel lift pump repair kit? in reply to Jacob Helton, 05-13-2003 19:25:33
jacob,find a used lift pump if you can,its cheaper,than buying a new one,i put a used lift pump on my 52 petrol and it seems to work just fine,and i had warranty for 30 days..make sure they are the same pump thats all.
