Fordson Major (i think?)
Tom
05-17-2003 11:27:18
I have just started tearing apart an old Fordson tractor. Can't find the serial number and don't know exactly how to tell the difference between all the different Fordsons. Any ideas out there?
darren
05-18-2003 03:16:22
 Re: Fordson Major (i think?) in reply to Tom, 05-17-2003 11:27:18
G'day tom,
I to am restoring a fordson and happen to know a bit about them. If it has a big cast iron top on the radiator
have a look under the right hade side at the back of it and in towards the water pump you will find some build numbers which will say E27N thats the model the build date you will find on the big
end caps on the end of the conrods.
I can tell you that the engine number is stamped
on the right hand side of the block above the magneto but just below the head.
If you want to talk more i will gladly help you out with any info.
You can contact me on Walt@iprimus.com.au
